Dom
I find that in order to keep the inside of the windscreen clear from steaming up I have to use the AC button quite a bit. Anyone else find that
maybe you have moisture in the car from a spill or having the roof or window open in the rain ???Ireland...isn't it rather humid there? That would contribute to fogging.
Do you have a haze on the inside of your windscreen? If yes, get rid of it and see if that helps.I find that in order to keep the inside of the windscreen clear from steaming up I have to use the AC button quite a bit. Anyone else find that
A really old method was to cut a potato in half and rub the surface over the glass (true).
