K&N Typhoon fittings
dtrail7a
Iowa and everywhere
I know I should not have started a thread for this, but I'm pressed for time so I apologize. Does anyone know where I can order one of these that is not plastic, but still I piece? TIA
Damn. Good luck finding that, maybe you'll have more luck as youre in the US. I purchased the AEM kit (essentially the same). They forgot to supply that 90degree piece lol.
They were unresponsive to me through emails. Luckily my parts guy I bought it from was able to get me one but it took two tries. They sent the straight one first instead of the 90 degree fml.
Anyway, it's an oddball size 1/4npt to 5/8 hose Barb. Easy to find in a straight, less common in a 90degree.
Try getting a hold of k&n directly or go to a local plumbing/HVAC supply store in your area.
After a month I was able to find a couple brass ones, but they were pricey. Good luck
Fml indeed. That sounds like a pain. Thankfully I managed to ride my Segway to a local hardware store and got some stuff to get by. The hole is a bit smaller than the stock piece and the nipple is too small for the hose to fit tight without a clamp.
Thanks for sharing. I'll see what I can find.
K&N sent me a replacement, for free, either overnight or two day. Just call them.
(Edit: sorry, i just read that you dont want it in plastic)
That works. I will get ahold of them. Thanks buddy.
The fittings suck.. never fully tight, especially when the engine is hot.. I might try to find those brass fittings now. I did get a extra set directly from k+n for about $20 shipped though
