Doesn't really matter, I'd just stay on the latest stable (I think I'm still on v27).
But go into Settings, View Tuning/App Configs, App Settings, Logging Settings and make sure your WOT Autolog Threshold (Pedal) is set to something reasonable like 70-80% (and the Timeout to 3-5 seconds) so that it will only log when you're doing an aggressive pull.
You don't necessarily need to hit 120, but if you can start around 10-25 and hit 70-85 before you lift, that should ensure you kick down and record at least a couple gears through redline. Hopping on and off the throttle will still make it log but won't give you anything useful.
