Tonkabob
2500 Posts Club!
Seems the trunk will get over 120 in the summer sitting in the sun.As long as pump temps are below say 120F it should be fine. If it's too hot fluid evaporates in the pump heat and causes vapor lock.
Fires occurred from fluid leaking out of the factory washer fluid tank/neck, lighting off the exhaust, not from meth lines themselves leaking.
