Stinger Nash
- Nov 21, 2021
So, I have JB4 with WMI kit installed was working great now nothing. no flow... Purge works no flow at all.??? Any ideas? TIA
I'm sorry what is CSV log?If purge works then its likely a software setting. CSV log?
Thanks, I will get a log in the morningsend Terry a log. CSV file is what he wants. have you done a log with your JB4 yet?
Thank you for your response. I found it was my E85 settings. I had them out of whack! HAHAI had the same issue when I installed mine 2 weeks ago. My issue was I plugged the power wire fork into the fuse slot as it was instead of cutting off one side of the fork and plugging into the hot side of the fuse slot only.
