Jb4 without intakes?
StingerGT77
I’ve been wanting a jb4 for quite some time now but for reasons I’m not willing to get intakes. Does anyone know what map(s) I can use with just the jb4 and spark plugs? I know map 1 can be used with completely stock everything but I was more curious about the other maps and couldn’t find any threads on here about this.
The maps are based on fuel quality, not mods. 93 octane map2, E30 map3.
Just curious, Terry...is Map 4 not recommended when using approximately E30?
I've logged several runs in all maps up to and including Map 4, and it appears to run very well.
Map4 can work well on E30. For anything over map3 we suggest logging and evaluating it.
I run map 3 with no issues. I used K&N drop in filters, ARK secondary downpipes, HKS m45il spark plugs set at 023 gap, and velossa tech big mouth snorkels. Occasionally I run an E30 mix. (Note) I did not remove the air dam in the front I held the snorkels up for fit and just trimmed out a small section on each side. No need to do all that disassembly and rewiring. My best dragy time from 0 to 60 was 4.01
