Jb4 tuner
Underdog
Anyone have the jb4 tuner installed? I have a 2019 Stinger GT2 RWD. I’ve also installed a Borla exhaust and the Ultimate Performance down pipe/mid pipe. i run on Map 3 (91 octane) and map 4 (93 octane). This will be my 3rd misfire when accelerating. I now have tuner turned off. I’ve been told there is too much air being drawn in and car computer sends extra fuel which causes a misfire. Does my car need to be dyno tuned or is it something else? Please help.
Thank you
What spark plugs are you using? What do your logs look like? BMS does not recommend going past Map 1 with 91 octane for a reason. Who told you too much air is being drawn in? Fuel wires? EWG wires?
I just ordered EWG wires. Did not know I needed them. Maybe this will correct problem. I use Denso high performance plugs gapped at .022. My bad. Map1 for 91 and map 2 for 93
Post up a JB4 log if you need tuning advice.
Are you injecting other fuel as well?
Otherwise you are not supposed to use those maps with that grade of gas.
Map 1 is for 91 octane, and Map 2 is for 93
Map 3 needs water/meth injection or running an ethanol mix
So if you are using Map 3 on just 91 octane then yeah, the jb4 is doing everything it can to keep you from damaging the engine.
