k8blackout
- Apr 25, 2023
Hello! I've had the JB4 on my Stinger ('21 3.3tt RWD, 57k) for probably a good six months now, at least, and I've had a lot of time to mess with it and such. I've got intakes, FMIC, and Denso 1 step plugs, the Densos are anywhere between 12-16k miles but have felt good up until now.
To preface, I did go on a drive the other night during a pretty heavy storm and drove through some pretty deep water, nothing crazy, but definitely more than ankle deep water in some parts, and all of the issues below happened 15-45 minutes after said water exposure. So it's not necessarily the smoking gun, but keep that in mind I guess.. lol.
So after my little drive I began to notice my car was having trouble under ~50% load or greater, the JB4 gauges freeze, the map resets to 0 (i can only tell after restarting the app since it's frozen), but the app is still responsive. I have the windshield stalk map hotkeys and those still update when I change them while the app is frozen, but the gauges like RPM, boost, etc... all are frozen at some value. The bigger issue is my car has this weird sputtering/struggling feeling above 8-10 pounds of boost. I've tested it in Map 8, 0, 1, 2.. map 8 definitely does it the least, and in anything Map 0+, it's more often than not that it gives that weird sensation. It is a similar feeling to if you've ever had a bit too much boost and the HPFP starts to struggle to provide gas, or similar to if you have bad plugs. Sometimes it runs fine, smooth as butter, and other times it will start sputtering really badly and I refuse to hold on the pedal. There is a third scenario where it kind of lacks responsiveness, and progressively kicks up in power until it's at full boost. Since the JB4 app freezes, it's kind of hard to get a log because it stops logging too. I tried to use one of my external scanning tools but it isn't fancy enough to get good readings for me to actually make any conclusions. There are also no CELs or other issues.
I am planning on changing the plugs, since they probably need it anyways, but I pulled one the other night after the issue began and it honestly looked fine; clean, had a lot of electrode left. Sure, one of them could be bad or cracked, so I will replace them, but I fear that's not the issue.
I have already tried fully removing the JB4, however the issue still occurs. This is what leads me into suspecting it's a wiring issue - the JB4 freezes/crashes, so perhaps there's a short or some sort of surge coming from some area of wiring that the JB4 uses, causing it to do that? It would be helpful to know where exactly the JB4 pulls its power from, or if anyone's had a similar issue and could maybe guide me to checking some areas of the car for corrosion or issues, that would be great.
I know there's not much descriptiveness here, and I could go and take a video of it actually happening, but I will at least attach some logs that may be of help in diagnosis. They're all labeled either good, bad, or culprit, meaning the car ran fine, the JB4 crashed, or there's some value out of place that may be able to help diagnose the issue. Any help is appreciated, and do ask if you need any more info. Thanks y'all.
FYI: I labeled the Map 0 and 2 'culprit' because right before the logs stopped, JB4 crashed, and map reset to 0, you can see IGN1 crash.
Bad Map 1 is just a short and sad map where it crashed right after logging began. Not much I could do. I tried progressively pressing the pedal on some of the logs too to try and get it to at least get under boost before it crashed, generally with no luck.
