3.3TT Is this right
runner1
multiple runs in my 2019 Awd gt2 and with launch control I’m getting 5.1-5.2 0-60 on 64 degree night. Seems slow to the data I’ve seen. Using launch control and no paddles. No mods, running esso91 but just added shell 91 half tank before trying. Ran maybe 10 attempts. The launch is really soft for awd but it is what it is. 3000 miles on the car.
90m above
I'd say that's probably right around where I'd expect a stock AWD to be. I think the reviewers with the really fast ones (4.6s 0-60, etc) got some factory freaks.
mods start in the spring and I expect mid 4’s on a jb4 and intake but I guess I had higher hopes.
I’ve read of some people getting better numbers without using launch control.
I feel bad for you guys, over here you can't get fuel under 95
and I would say with 102 the car sould be easy under 5s
but to be fair we pay 1,40€ per liter 95 -> 1,54$
ultimate/102 is about 1,75€ per liter -> 1,93$
You're talking RON vs AKI though, right? Your numbers appear higher than ours. But 95 Ron is 91 octane I believe.
OP, dont feel bad, I couldn't get into the 4s with Map 2 and intakes on our gas (2200 ft alt). Still trying...lol
I had to do a reseach to answer. I have never heard of RON or AKI before :rofl:
anyway, in germany the numbers are in RON. So it's 102 octane RON and 95 octane RON
This seems right,
Injen Intakes with an ark catback and the best I've gotten is 4.8 0-60. Mind you this is also with a 300 pound driver.
Stock at 5.1 seems aboit right.
Pretty sure Kia's advertised 0-60 and most people running sub-5 to 60 stock did so with RWD cars, especially base GT's. The GT2 AWD is the heaviest version of the Stinger, easily a couple hundred lbs, at least, in weight difference between the added AWD and features(sunroof). Traction isn't a huge issue for RWD Stingers at stock levels.
Best I ever got out of mine (AWD GT) was a 4.95. Most were 5.0x-5.1x so I'd say yours is about right. I'm timing mine by getting a video of the cluster and then looking at timestamps of when MPH is no longer 0 and when 60 shows.
I was mid and high 4s stock. AWD. But that’s at sea level.
I'm at about 1600ft. I've also only timed it 4 times so there is a chance I could get better times by changing up the road surface, procedure, etc.
I just did mine with a dragy and the best I got was 4.9 on 91 octane at 4500ft elevation. I've got CAI intake and JB4 running map 2. That was also without launch control and instead disconnecting the brake and launching at a little higher rpm than stock.
All the advertised times (including C&D's 4.4s 0-60) were on RWD GTs with LSDs.
Get 5.0 with map2 at about 1k elevation. I know they aren't the fastest off the line, still pulls like a mofo though.
Not my experience at all, very hard launch even when stock. Are you sure you had the pedal completely floored? There's a "detent" or similar that you have to push thru to get true full throttle.
I wish I could find a record of it but I'm certain I was in the high 4's stock. Post tune, 4.2 "officially". I've done better but for some reason don't have a record of it (logger issue).
What elevation are you at
~1000'
