Jenny Wang
Founding Member
Hi people. Is map 5 safe while using 93 octane with the 450 wheel hp package? If not which is the highest map you can go?
Thanks! Can the logs be sent through the app? Or do you need to email them?Map 5? No. Start on Map 2 and look at the logs (or send them into Terry). Might be able to reliably run Map 3.
Start with map2 and evaluate it. Usually map5 requires E85 or octane booster mixed in.
Kia & Hyundai JB4 - N54Tech.com - International Turbo Racing DiscussionTerry, So what octane level is map3 made to run with? 96?
can I run map 3 or map 5. because im using e30Start with map2 and evaluate it. Usually map5 requires E85 or octane booster mixed in.
Im on Map 3 while driving and it change by it self to Map 1.
Just installed my jb4 on a 2017 440i coupe. On map two I'm hitting 4.1 0-60 with no other mods. Stock was 4.9-5. Not sure what the quarter mile is yet but, I will in a couple weeks. Also getting intake by then.
