Darwinian
- Sep 28, 2021
The aircon in my 2019 Stinger GT intermittently stops cooling while driving, often after about 5 minutes of driving after being parked in the sun for the day but sometimes more randomly. It'll mostly start cooling again after going around a corner (or maybe a bump in the road)! I've got an OBD2 monitor connected and can see that the AC pressure drops instantly to about 12 psi when the problem occurs, then jumps back up to normal (120 - 150 psi) when it comes good again. Dropping down gears to increase RPM has no impact. The cabin filter has been changed with no impact. The local dealer just fobs me off ("we're not able to replicate the problem") and it's a 3000km drive to get to another dealer, so I'll do what I can to either fix it myself or at least try to get enough info to be able to tell the dealer where to look. Does anyone have any suggestions, or any info on the cabling, switches, component locations etc that might help?
