Im not sure why my ign 6 is always pulling more timing then the rest. I pulled the plugs, checked the gap, swapped plugs with one that wasn’t experiencing timing pull, same thing happens. Placed ign 6 with a new coil pack in there as well Same thing.
Could be false knock being picked up. Could be even the spray pattern of the injector causing it. Do a ecu reset with disconnecting the negative on the battery wait 5 min and reconnect. Wait a day or two and recheck the log. Nice YouTube videos also seen a couple of them! Try adding some E85 if you have available and that will clear up allot of that timing you have going on
Thanks for watching! And im going to reset the ecu tonight to see what happens. Replaced the plug with a new one and switched a coil pack with one that wasnt pulling timing so and it stilm happens so hopefully ecu reset fixes it
