Humming noise at 50MPH or higher
street heat
anyone else experienced this ? doing online searches this problem is usually attributed to bearings but Id like input if anyone has any
also, I recently got aftermarket wheels installed. I dont know if that has anything to do with this Im just hoping its nothing serious.
The hum I experienced briefly was a worn outer edge on the my LF tire; actually had a small section of lifted tread.
Could be an alignment is needed. Also could be bad fitment and rubbing. Does the humming happen around curves either direction at that speed?
