How to add washer fluid? 23 GT2
joshua05
Bought a 2023 GT2 grand tourer CPO a few months ago, and now I'm getting low washed fluid chimes in the car. I assumed they would top it off at the dealership when I got my oil changed, but I guess I was wrong. I went and bought some fluid and went to go locate the reservoir, but it looks like it's covered by this panel? Anyone seen this before or know how to get it off? I fiddled with it a bit but didn't want to start pulling too hard on things.
You would have to first remove your aftermarket vanity cover that the previous owner installed when he/she had the car piggy back tuned.
A better aftermarket cosmetic cover is this one, which retains the ability to fill the washer fluid while hiding the piggy back tuned.
Thanks DJ. So this is a sign that the car had an aftermarket tune installed? Do you have any idea how to get it off (tools required) or does that vary widely depending on aftermarket brand you go with?
Just remove the 3 plastic push rivets
List io the inner part.
Small flat blad screwdriver can get it done
There is an actual tool for this, but you do t need it
