Landboat G80
- Aug 29, 2021
This vehicle is not under warranty.
Current modification list:
- JB4
- Intakes
- Exhaust (Secondary Delete)
I currently have a missfire issue that is not throwing codes. There are rarely any misses in MAP 0 (They do still occur) however between MAP 1 and 3 the miss-fires get progressively worse at anything over around 30% throttle. These seem to only happen during the first 3-4 seconds of heavy acceleration and then they're gone. The missfires are pretty violent, sounds like a big stutter, a small but quiet pop, the car kicks a little and immediately picks back up.
This issue started when I installed an ECU Tune which had some over-boosting issues. It's been removed and returned for the time being. I had to replace all of my plugs after that which cleared up around 99% of the issues, before I couldn't even accelerate, I had to limp the car to a mechanic to have the plugs changed to HKS M45IL's. I only did 3 WOT pulls on this tune, the rest of it was just limped around to get home and to a mechanic.
It doesn't matter how often this miss happens, it will not throw a code. I've even (against my better judgement) made it miss a few times on purpose to get one, no luck.
I'm running 93 Octane Fuel, According to the JB4 "Virtual E85" Gauge my estimated E content is around 13.
I thought maybe this could have been a bad tank of fuel, but I ran it empty and filled back up and still no luck.
I don't *think* it would be a coil since it only happens under heavy throttle, but I'm not very mechanically inclined.
Any guidance of diagnosing this issue would be greatly appreciated.
I currently have WMI, Fuel-It, and EWG wires sitting in my garage and an intercooler in my shopping card, but I'm waiting to install it because of the missfires, lol.
Trying to figure out which cylinder so I can check the coils.
EDIT: I have gone over several of my JB4 logs during this happening and event sent some to Terry, fueling isn't perfect but it's not maxing out trims by any means. I don't feel like it's a fueling issue, but I may be wrong.
Also I noticed my Idle AFR is sometimes sitting at around 12.9/13.0 but most of the time it's 14.7 like you'd expect.
- JB4
- Intakes
