Hit pole messed up bumper. Help
Venum009
Chicago
So as it says somehow I reversed into a random light like or something I’m not sure I didn’t hit hard I thought so just thought it wasn’t anything but turns out it’s bad I need a new bumper, left tail light, diffuser I think that’s it. Does anyone know where I can find these at a reasonable price my car is the white gt2 I’m paying out of pocket as I don’t want a claim just would like some advice on finding these parts or if someone has parts or even aftermarket as long as I’m at it to make it cooler. I’ll try to attach pictures but it ended up being way worse than I thought. Might do exhaust as long as I’m here . And my brother owns runs a big Kia dealer near me so I’m hoping he will help me out install wise but even if he was nice and gave me half off I’m better off finding items else where witch is why I’m here. I found some on eBay but the bumpers most are rough and I’d like to avoid paint as much as I can scratch light I can work with but some are just destroyed on there and tail light seems easy as long as the center one is fine and it looks ok I’ll check again. Sorry I’m just broke and super depressed about this and need it figured out asap as I wo t drive it like this just because
Does your blind spot warning still work with that radar smashed in on the bumper?
There's most likely damage under that you're not seeing too
Yes all that works . Well should I didn’t hear it before and neither did my friend in car when it happened but it was beeping and working properly when I got home luckily . So I’m good there and no faulty lights
I’ll see after my brothers dealer really takes a look but everything seems to work. It really wasn’t a hard hit even though it looks like it I’m surprised how much damage
Ima sure it was a press more than a *crunch*. So your probly right about no more than cosmetic damage. I completely understand and sympathize with not wanting to drive it this way. You can fix most of that appearance wise so that it doesn't advertise. Look into paintless dent removal service to pull that pushed in part back out. reattach the cover. Check out "YouTube University" for ideas on how best to touchup the damage, until you can fully heal her. You should be able to endure the damage as long as it isn't so danged obvious. At least do your best while researching parts and etc. May it all go well.
Where you located?
besides the tail light, I also have that OEM rear lower diffuser if you want it. It also has a painted to match M&S diffuser added on.
