MGeezy
Sustaining Member +
- Jul 11, 2023
I am not the best at reading the logs on my JB4. Any help would be greatly appreciated. I am running around a E25 blend with 93 on Map 3. I installed ewg wires due to overboost. Now my default waste gate position is 50 and the ff waste gate adaption is at 40. Should I change the ff to 45 for a little more boost? Also my mods are aFe intakes, MBRP Active exhaust, jun BL downpipe midpipes, HKS plugs .022 gap, bms pedal tuner, and VT ram air ducts. Thanks in advance!
