Help needed with centre caps
Stanger21
United Kingdom
I have the 2021 facelift wheels on as standard but recently picked up a set of pre-facelift staggered wheels with winter tyres to use now the weather is taking a turn for the colder.
I picked up a set of genuine Korean E centre caps for them but have found they'll only fit the fronts, am I missing something? They all have the same part number and came as a set of 4 so assumed if there was a different fit for front/back the that would be catered for.
I've tried to seat them in place but they just won't clip in like the fronts do...
That is frustrating!
Have you tired each of the five possible positions?
Have you pushed really hard?
Are the lugnuts all matching?
With the "E" cap removed will the main lugnuts cap fit?
Not tried rotating them to different position but it's a good call. The fronts just snapped into place perfectly but the rears just won't have it.
Interesting you mentioned the lug nuts, I did wonder if they're too long and that's what's stopping them going in far enough. Will check tomorrow and also try removing the center logo to see if it makes a difference
My number one guess is the lugnuts. Impossible to say from a picture, but they look bigger than what I remember mine are, which is why I mentioned it.
Bit of research uncovered it was the lug nuts after all...
Have ordered a set of the old style nuts p/n 5295014140
Score! But are you saying that your front lugnuts are conical and your back ones are the taller variety? I remember that thread, and an earlier discussion about the wrong lugnuts coming loose. Your original GT wheels use the conical type, not the bigger ones.
