Help needed reading graph
Itsleo3
Hey guys so I know basically nothing about tuning and recently ran a e30 mix map 4 and was wondering if anybody who knew how to read these could tell me if I’m doing everything right and everything is running good
Its best to post the .csv file, not the graph. Attach it to the next post so we can pull it down and analyze it.
+1 on CSV
Your csv files are empty, nothing in it but blank values. Did you record without the engine even running? There are 0's for RPM, Pedal, and pretty much everything. You have to record a WOT run in one of the Maps, preferrably through a few gears, or from a stop through 100mph. Even a third gear pull will help.
