Sorry about that. There are 3 vents in the center and one vent to the left of the driver by the window and reverse on the passenger side. AC comes out these vents. Why doesn't the heat? If my hands are cold I could put it in front of the vent for warm air, but there isn't any. Eventually the cabin warms up, but doesn't help my cold hands in the meantime.The heat typically comes out of the floor (warm air rises, cold air falls) vents with a blend from the center level/console vents. To your statement, there are no hand vents. If your car is warmed up, you should have a comfortable cabin depending on the heat setting. If you could give a better explanation on the issue you are having, we can get a better idea of what you are experiencing.
Your right I noticed this the other day, even set on auto it sounds like most of the warm air is coming out of the dash windshield defrost vents.
It does if you change the airflow or if the “puter” thinks that is appropriateSorry about that. There are 3 vents in the center and one vent to the left of the driver by the window and reverse on the passenger side. AC comes out these vents. Why doesn't the heat? If my hands are cold I could put it in front of the vent for warm air, but there isn't any. Eventually the cabin warms up, but doesn't help my cold hands in the meantime.
No. Garage kept.Do you park your car outside?
How do I change the airflow? Where's that setting? I'm pretty new to my car, so I haven't figured it all out.It does if you change the airflow or if the “puter” thinks that is appropriate
in auto (in the cold) the auto setting typically is defrost and feet.
And read the manual............. there are lots of fascinating words. Beautiful words. The biggest words. Believe me.As above but press the Climate button first so that you can see the airflow positions on the monitor. Warm air should flow from all vents.
That’s the dictionary...lol.And read the manual............. there are lots of fascinating words. Beautiful words. The biggest words. Believe me.
