Headlights
Mandijo
Does anyone else have issues with their headlights only having low beam and I can barely see anything when it's dark
What year and trim level do you have?
Howdy and welcome. That is a first in my experience. What is very common, though, is the low beans set too low: they need to be raised. If your high beams don't come on, that is likely not a headlight assembly problem but could be in the stalk/switch. Warranty for sure.
just got a gt2 and thought i was going blind, Low beams are super low not even going to try with dealership unless theres a TSB?
Adjust them using a screw driver.
the first time i drove it at night it was literally dangerous how low they were!
search for headlight adjustment post ... little gray plastic "funnel"-looking things on both sides near headlights, stick long-handled (#2 i believe) philips screwdriver in to adjust - super easy. they are even labelled which way to turn for higher or lower.
