Okay what do you mean by disparate OD front and rear are you talking about how the diameter should be the same or really close?It isn't the width that is at issue. You probably are AWD with disparate OD front and rear. Don't do that! You'll kill your transfer case.
Wheel and tire front 18x8.5 et30 245/40/18What are the dimensions of your wheel and tire setup?
Gotcha so what matters more is the aspect ratio and keeping it as close as possible to one another whats the max that it could be for awdRears need to be 295/35. Second number is a percentage of the first. 245*.45=98. 295*.35=103.25. 285*.35=99.75 would be a better choice for AWD.
Yes, really close to the same OD. Not 6% off. Your rear OD is 1.06 bigger than the front OD. No wonder your warning light kicked on!Wheel and tire front 18x8.5 et30 245/40/18
Rear 18x9.5 et40 295/40/18
