Yup, I installed the sport brake pedal cover and accelerator pedal mechanism on my 2.0 Premium last week. Only took about 15 minutes.View attachment 7524 Just curious to see if anyone installed the sport brake pedals on there 2.0 and if so how difficult was it to install and what tools where used ?
These are the ones I’m talking about
@Bryan2.0, when I wrote dead pedal, I was referring to the left footrest.Had the dealership do mine. As @SEA Stinger noted they are an easy install. The only thing that sucks is the footrest needs to be covered too. The kit doesn’t come with one for it.
Replacing the brake pedal cover was simple. Just pulled the original all-rubber cover off the pedal, starting with the large flap on the right edge. Then worked the new metal and rubber cover around the edge of the the pedal. The steel cover plate has four clips that grasp the pedal; to push the clips into place, I firmly tapped a rubber mallet on the face of the cover plate a few times.
Replacing the accelerator pedal mechanism was almost as easy. Used a socket wrench with 10 mm socket and 2 inch extender to remove the nuts from the two bolts that fasten the pedal mechanism to the floor. Then removed the spring clip that attaches the sensor and pulled out the original pedal mechanism. Installing the new accelerator involved reversing the process - snapped the sensor clip into place, set the pedal mechanism over the two bolts and attached the two 10 mm nuts. Replaced the two small plastic covers over the bolt holes.
Dunno about the installing the steel dead pedal. Since my Maxspider 3D Kagu floormats cover the dead pedal, I just ordered the brake and accelerator pedal set.
The picture that @PStinger18 posted shows a set with a stainless steel cover for the dead pedal included. Sets are available either with or without the dead pedal cover.
Looks like you have a Base 2.0, which has a mechanical parking brake. I am not aware that a sport version is available for the mechanical parking brake pedal.
Curious as to what the dealer charged you for product and install?
That seems to be the going rate for sets with the dead pedal cover included.Awesome sounds simple enough and by going with your directions sounds really easy to do , that picture was a set i seen on eBay selling price was for $85.99 and i have an eBay $15.00 off motor coupon is that a good buy or can i get them else where cheaper ?
As mentioned, I just got the accelerator and brake pedal cover. It was $57.98:
OEM Parts Accelrator Brake Sports Pedal Pad Set 2P For KIA 2017 - 2018 Stinger 8809588987381 | eBay
