This is my third lowering spring and finally I found the right ones. As most of you know all the lowering springs available are built for the AWD, so on the RWD the car looks like it is squatting.
H&R recently introduced lowering springs for the RWD (Part #28701-2) and the drop and stance is very nice. The front is a little lower than the rear which is perfect, because once you drive it evens out and it will not squat too much if you carry people in the rear.
The fronts are a bit softer than the Eibach, but the rears are significantly stiffer. The car turns better and feels sharper for some reason.
