My 21GT definitely has it. When you hold the traction control button down for 3 seconds you should get a warning that stability control is now off too. This is required to be off for launch control to work.Do you get the stability control warning?Do GTs have launch control? '21 GT and I've tried twice now but doesn't seem like anything's happening. Sport mode, turn off traction control, depress brake, pin throttle but no light came on.
What gives? Only a GT1/2 thing?
LC is built in (safer) and under warranty.What is the difference between LC and just brake torqing it? I seem to get the same RPM either way before Launch
launch control (or lunch control as a former coworker called it lmfao) is better for the car so do it that wayWhat is the difference between LC and just brake torqing it? I seem to get the same RPM either way before Launch
my 2020 GT has launch control as wellMy 21GT definitely has it. When you hold the traction control button down for 3 seconds you should get a warning that stability control is now off too. This is required to be off for launch control to work.Do you get the stability control warning?
