Green fluid on garage floor. Driver side
Ek9max
Calgary, Alberta
Just noticed some green fluid on my garage floor. Coming from the driver side. Would basically be under my butt.
Any ideas?
2018 GT LTD AWD in canada.
If I was you, I would wipe your garage floor clean and run the car a bit while parked, you might be able to pin point the location of the leak.
This far back, Maybe from the turbo? The other component far back with coolant is usually the heater core.
There are a few hard lines that connect both sides of the V at the back of the block, maybe one is leaking.
