Fuse Question
D.J.
2500 Posts Club!
Toronto, Ontario, Canada
I use this 10A
why you need over 15A?
My dashcam (typical dashcam - A119 V2, from 2016) - draws about 0.4A @ 5V (closer to 0.17A at 12V) - it's very insignificant from a current draw perspective
picsart_12-13-11-46-10-jpg.83350
Hardwire Kit InstallationDedicated Hardware Kit ASIN: B09X1L1GMX or B0BBLCCQ2BMuti-size Hardware Kit ASIN: B09X9F8GMT1. Stop the engine.2. Open the fuse box.3. Use a power detector to detect the constant power and ACC power (emergency power). *note:Use an ACC power supply of 15A to 25A. Use a constant power supply below 30A.4. Connect the yellow fuse to the constant power source, the red fuse to the ACC power source,and the ground terminal (black wire) to the metal part of the body.
These are the instructions with my cam
Don't get 'em from amazon...
I like the quick reference chapters.
very convenient.
Louis does good work.
00:00 - Intro
01:20 - Precursor to testing the fuses
02:41 - Demonstrating my test setup
04:55 - Getting started!
05:03 - Starting with nilight fuse
07:10 - 6 amps through a 2 amp fuse
07:41 - Louis goes to take a piss
08:40 - Louis washes hands
09:09 - Louis finishes
09:20 - Louis goes to grab a bottle of water from 2nd floor
10:15 - Louis fks up the sound in his video.
11:03 - The 2 amp fuse has been passing 6 amps for almost 4 minutes now....
11:37 - 8 amps through a 2 amp fuse
12:02 - I have to redo my setup so I can accommodate more power....
12:40 - Louis Rossmann is a moron
13:51 - Trying again with more powerful setup
14:36 - 2 amp fuse blows at 10 amps...
15:17 - An important message
16:25 - Trying another fuse brand, 5 amp fuse
19:45 - Not bad!
20:30 - Trying CrocSee 2 amp fuse
22:28 - 2 amp CrocSee worked at 2 amp, blew immediately at 4 amp!
24:39 - Tried experiment with crocsee again, same result - nice!
24:37 - DON'T TRUST ME + my conclusion
27:06 - Amazon's hypocrisy & my salt with it
27:30 - There is no policing of this marketpace
^^Yup. Going on 3 months now with no amz purchases. Trying my best.
