SteveCo
1000 Posts Club!
I'm not a fan of bare wire in the engine compartment, or of piercing connections into existing OEM wires. I decided to modify the JB4 fuel wires, from simple bare wires with stripped ends to use these weatherproof connectors along with braided sleeves ending in heat resistant harness tape. The bare, exposed fuel wires were covered with braided covering that matched the other wires on the JB4. The single wire weatherproof connectors I bought on ebay.
stingerforum.org
The braided connectors were then transitioned into the harness tape with heat seal tubing.
I also purchased fuel wire connection harness splitters, but cut off the supplied blade connectors and modified them as well to make a matching weatherproof connection.
I removed the supplied split plastic shield, and wound the wiring with the heat resistant harness tape. I secured the wound ends with miniature tire straps.
Original:
d
Modified:
Clean, tidy and electrically sound - works very nicely.
JB4 PNP Fuel Wire Adapter – The Stinger Shop
stingerforum.org
Original:
dModified:
