Shades_of_grey
- Aug 27, 2019
I will try to post a log tomorrow, but curious if anyone else is having or had this issue. Recently installed primary 200 cell high flow downpipes. Was throwing codes,but got non foulers installed and no more CELS. Now, in WOT, in 3rd, or even at 5th, once it shifts to those gears..it's almost as if the lpfp basket is running out of gas. It completely bogs, no power and it goes to map 0. I run E30 on Map 3 daily. Never had any issues before changing DP. Even went from a 1 step to a 2 step colder plugs gapped to .22. If I gradually increase throttle, no issues up to 175 (mexico). I also have EWG wires installed. In manual mode if I early shift (5200 ish, seems ok). For instance, today on the way home..doing about 65, floored it,kicked down a gear, shifted to 6th and then, felt like no fuel
.Just blah and went to map 0. Help?
