Front USB port not working.
Curry
Detroit
I took delivery yesterday and Front USB port isn't working. I rear USB is working fine and it is not the cable.
I also noticed that the wireless charging pad area is quite warm even though the Wireless charging option is turned off form the gauge cluster screen.
Welcome to the forum.
The charging pad gets piping hot, or, some have observed this and asked about it here.
USB charging port, or USB playback port?
on the QI charging unit, there is only 1 USB port on the unit. Charge and data.
Does the rear USB port have data/media connectivity on the newer model years? Because my GT1 only has the one data/media port in front. The rear USB port is charge only.
USB Charging port to use Android auto/car play
So, your rear USB port charges, and the front USB port charges? But you can't access media through the front port? Are you saying that your car has NO USB media access at all?
Rear charges. Front no media access and no charge
That is a warranty fix for sure. At least you have FM radio. :rolleyes:
