Front seat back panel replacement
smmrfld
Hi all...any idea how the hard plastic (with netting attached) front seat back panels are attached? Mine got goofed up, and I need to replace. There don't seem to be any visible fasteners, so am guessing that the old one just pulls off and the new one snaps on? Are left and right the same part? Many thanks in advance.
The above manual is free btw.
Thank you...that seems to be the actual cushion/seat back assembly. I'm just trying to replace the hard plastic panel with the net attached on the back of each seat.
It appears to the the front seat back board, but can't find a part number or installation info.
Oh, you need a part number? You should look it up.
Step 8 is for removal of the seat back board, aka the plastic back panel of the front seat that has the netting attached, which is the part you described. Did you review the whole procedure? Or did the whole page not load? (in which case try a different browser).
Have a look here.
I saw another video that was better but sorry can’t find it.
