Front Passenger Window Squealing/Binding
Redline
So, not sure if anyone else has experienced this but my front passenger window is sticking, squeaking, and binding going both up & down.
After lowering/raising the window about 4 times it stopped functioning altogether (with both the driver door switch and the passenger door switch). Not sure if it from the window being too stuck, the motor protecting itself from overheating, or something else. Fortunately, after letting things sit for about 2 minutes the switch started working again.
I was able to replicate the issue twice so hopefully the car cooperates when I take it to the dealer and they are able to do more than just hit it with some silicone spray.
If we hang out here long enough, we'll all hear of every part on this car failing somebody or other. This is the first failed door window that I have heard of in c. five months. May your repair go smoothly and under warranty 100%. :thumbup:
Oh, "And Welcome!"
I only had my 2018 GT2 only 6 weeks now...and I HAVE 2 PROBLEMS GOING ON (Which started 5 days ago)...FIRST, my passenger side window will not respond. I read the book....did what it said...Still No response...Called Dealership Which Can not see me until after the Holiday...But was Told by The rep. in the Maintenance Dept. to (listen to This) 'GOOGLE IT'…(WHAT!!!???) SECONDLY, (as I read the Forum On the post 'CHECK BLIND SPOT' always on. That's on too. There's Nothing In My Blind spot!
By after the holiday do you mean Christmas!?!?
Telling you to Google it is the laziest advice ive ever heard from a dealer...
