First log check map1
2020gtrwd
Idk if the log is long enough but any help would be appreciated hks plugs are gapped to .022. Just wanted to see how everything looked before going to map2
Looks great, send it on 2
Do you want to do a full throttle runs for your logs.
Is throttle at 99 not close enough to full throttle. Just wondering. I had the pedal down enough to where the kick down didn’t activate but I was running out of on ramp.
Things look good on 2. Unless you plan to add Ethanol run it on 2
No ethanol in my area so map 2
