3.3TT First Ever Log Check Please
ChaneRZ
1000 Posts Club!
Bay Area, California
Hi guys! Log check please. This is map 2 with 91 octane. @Terry@BMS
mods: intake/exhaust/hks plugs .022
Map2 has a lot of timing movement so your fuel is particularly bad. Map1 might actually be faster for you. You can run whatever feels best behind the wheel.
Thanks Terry! Crappy 91 CA fuel. I’ll stick with map1 from now on. Wish I had 93 fuel around me.
so is my map1 log good to go @Terry@BMS ?
Are the ignition logs in the + or - side? Negative correction is bad right?
