Hey all, I have a 2022 G70 3.3 sport with the factory valved exhaust. I wanted a way to open them up in comfort without just unplugging them. I understand the new Stingers also have the same system. Based on what I found the valves are somewhat universal between a handful of manufacturers. I found a kit from apr that works with dual exhaust valve systems and gave it a try. Sure enough it plugged right in and worked! I now have full control of the factory valves and can open and close in any drive mode at my will. Figured if it worked for me it may for you as well!!
This is the kit I used. There are a couple others around but this was the most complete I found without spending over $300.
APR Part # MS100170
APR Part # MS100170
