julianwithanx
- Aug 24, 2020
You got pics of them on the car? I’ve been thinking about this set up for myself.(4x) Enkei Raijin 18x8.5 w/ Continental
Extremecontact DSW 06 PLUS 255/45/18
About 15k miles on the tires. Includes sensors.
local nyc area pickup
Some scuffs around bolt holes and some cosmetic damage on one of the wheels as seen on the pic. View attachment 80186
Looks good AF. You won’t ship would you?
Road trip!! You travel enough, do it!Looks good AF. You won’t ship would you?
Yo you stopped posting on YT...did you sell your Stinger?(4x) Enkei Raijin 18x8.5 w/ Continental
What offset do you run with the 18x8.5” rims?Can't beat a nice set of Enkei 18x8.5 for lightweight alloys, without spending a fortune. 255/45R18 is a little tall though for the Stinger. 255/40R18 would've been much better. That's what we have on our G70.
GLWS.
Part number 516-885-6538 shown here: TFR | Enkei Wheels Offset is 38mm. On the front wheels, we run either direct bolt on, no spacer, or with a 5mm hub-centric spacer to correct within 1mm of the stock ET34. This maintains the same scrub radius as stock geometry. On rear wheels, no spacer necessary.What offset do you run with the 18x8.5” rims?
Do you use any spacers?
Cheers
Cheers thanks for the infoPart number 516-885-6538 shown here: 516-885-6538 Offset is 38mm. On the front wheels, we run either direct bolt on, no spacer, or with a 5mm hub-centric spacer to correct within 1mm of the stock ET34. This maintains the same scrub radius as stock geometry. On rear wheels, no spacer necessary.
