Samurai_JackEP101
Sustaining Member
- Jul 16, 2022
Okay so I have searched high and low for an Engine oil cooler install on the Stinger and all I have found was the trans cooler install. My thought behind this whole thing is I live in a winter climate, I plan on auto cross here and there but its also a daily so I need the oil to be the correct temp at all times.
I have this idea for an install. From my understanding the OEM oil cooler sits on top of the oil filter with barb connections for supply and return of the engine oil. I know the K8Stinger store sells an engine oil cooler kit but it does not come with a thermostatic valve for oil temp control. I found that Mishimoto sells both a universal oil cooler and an inline thermostatic valve.
If I took the return barb end from the OEM cooler into a barb on the Mishi thermo valve then barb back to engine and on 2 cooler connection sides go screw fitting to the cooler. Would that be the correct way to plumb that up?
Could even add an inline Mishi filter for an extra layer of protection.
It could also be replicated for the trans cooler (I think) since I don't think the BMS one has a thermo sensor either.
Links:
Mishi items -
Universal Oil Cooler Kit, 13-Row - Universal cooler - would get with out sandwich plate and get inline thermo instead
Mishimoto Inline Oil Thermostat - Inline Thermo - also allows for easy change out of the thermostat part incase you wanted the oil to be cooled more or less often
Links:
Mishi items -
