Thank you. I will have to call the dealers to see if they have any. I noticed that Rock Auto only has filters from WIX. I'm using a WIX oil filter. But I don't know if WIX has good filters for the engine/cabin? Thank you.If not from the dealer - Rock Auto is good as recommended above. One thing to consider is if yours is still under warranty, getting your parts from the dealer provides a record (keep your receipts) that you used OEM parts for your maintenance. That could be important in the event of a major warranty repair and saving the few dollars not worth it.
