Electronics not working
JJeasy
Hi, I have a problem with my stinger. Namely, several things in the interior do not work, the wiper sensor/automatic wipers do not work. The air conditioning does not turn on (gas is topped off) and the fuel filler opening does not work. Has anyone encountered anything like this? Where to look for the damage? I should also add that the windshield was not changed, only the filler was changed probably from the American version to the European version. I know that the Kia has a closed circuit of the electrical system but does it matter?
Check the battery. That's all I can think of.
And fuses? A blown fuse could knock out several things at once.
A bezpieczniki? Przepalony bezpiecznik może zniszczyć kilka rzeczy na raz.
Battery and fuses under the hood, by the drive and trunk. I have no idea what could have happened, other than those three things everything works. But on your advice I will check again.
Lol. That's the only time I've seen myself quoted in, what I take it as, Polish.
Hah,nice. I use automatic translate maybe that's why.
Returning to the thread, I checked the voltages on the receivers. There is 0volt going to the fuel filler even when the button is pressed. There is 4volt going to the A/C compressor, whether the A/C is on or not. There is 4volt going to the windshield sensor, it is possible that it is faulty because when I shorted the gray and brown wires something under the dashboard opened and closed and the thermometer showed ----.
I checked all the fuses. Is there perhaps a modem somewhere that controls these three things? I know the kia has a "closed circuit" and without one thing several may not work,but could this be the problem? Unfortunately my forum search skills are tragic due to the language barrier. I would like to add that when the car came to me none of these things were working and the air conditioning system was filled with twice too much refrigerant. And we changed the left rear door could this have affected? Installation definitely not damaged/broken after the accident because there was too little damage.
"Modem", I don't know anything about. But I do know that MY18 GT1 has 33 computer modules. All the technicians have are scanning tools to track down error codes. I hope that will work for you.
W stanach jakie pewnie mają, w mojej okolicy niestety nie ma elektroniki samochodowej. Ale spróbuję coś znaleźć
