For Sale Eibach Front and Rear Sway Bars (NoVA/RVA/DC/MD)
FreePreview
Selling new Eibach Front/Rear sway bars for $380, would like local pickup, but I'll ship if a buyer pays shipping. Shipping these would probably be more than what you can find them online for elsewhere, so local pickup heavily preferred. I'm willing to drive ~1hr one way to sell, so if you're sort of nearby we could find a middle ground to meet.
I purchased these in December, took a month to show up, and have sat in the box since. I opened it, looked at them, and put everything back. Was waiting for warm weather to install, but priorities have changed and I need to sell these now. I purchased them on sale from Hoonigan for $380, so selling them for that. ~$60 cheaper than the usual sites. Not interested in selling them separately.
Drop a message below or send me a PM if you're interested.
Attached pic is from when I opened them. They're currently in the large Eibach box re-packaged.
I'll take'em off your hands if they are still available. I'm south of NOVA and north of C-ville, so should be well under an hour drive. This weekend is the earliest I could get them.
I'm actually really close to manassas, so it's probably even closer. Is warrenton close enough for you to meet?
That's perfect, I am around Culpeper area so Warrenton or any where up 28, if your on that side. Got my stinger from Brown's Mannassas Kia.
haha no way! That's where I go for service. They tried to scam me with phantom charges when I tried to buy a stinger there, so I ended up buying mine out of state. are you able to PM me? I haven't posted enough to unlock that yet.
No I don’t think I can either. I’ll try to make a few more post later today. I’m 100% in on buying the sway bars though.
I've edited the post and dropped my phone number in there. Just shoot me a text
How To for the Front: (taken from a member on these forums, can't remember who)
Raise car on hoist
remove centre caps
remove 5 lugnuts per side
remove both wheels
remove 8 underbody plastic clips with trim tool
remove 4 underbody bolts
remove tray
disconnect 2 power steering wiring harnesses
remove 1 nut per side on the end of the endlinks (nut requires allen key and wrench in a tight space with obstruction once broken loose)
remove 4 bracket bolts and drop oem bar
remove 1 bolt per side on the oem bar
attach both oem endlinks to new bar 1 bolt per side
lubricate inside of new bushing and slide them onto new bar
slide new bar into place on car and align endlinks to slide into place by strut
reinstall endlink bolts 1 per side
slide in new spacer bracket and put new brackets over new bushings
tighten 4 bracket bushings
plug both power steering harnesses back in
reinstall tray using the 8 plastic clips and 4 bolts
reinstall both wheels and torque to 90ft/lbs
lower car
Helpful links for the rears:
