Hello,
First post here. I dont have a Stinger, but have a close cousin G70 with 3.3T.
I have been reading that you can run E30 fuel on the JB4 on Map 3 i think it was. Map 3 has a higher boost level that 1 or 2, i am assuming.
So I want to make sure that the E30 is only used for octane improvement. The stock ECU will control the fuel properly and the car doesn't go lean, due to the lower stochiometric value of E30.
I have read that the fuel pump is good in factory form to provide fueling up to E40. So E30 has some headroom.
So if i have a RaceChip GTS and want to run the highest setting of 7, then it should be the same as a JB4 with no fuel wires. Because no fueling adjustments are being made with the JB4 due to no fuel wires. So in effect, the JB4 is acting as a boost controller and turning up the boost ONLY.
Or to run E30 and Map3 does that assume you have fuel wires.
I am hoping that the E30 works with increased boost, like cheap race gas, and the stock fuel system and control will maintain stock fueling lambda values.
I have read what I can find, but still just a little un-clear.
