Door seal repair
Qywn
Florida
Need some suggestions on how I could repair my door seal, long story short , accidentally cut into it , tried to glue it , went horribly bad, had to cut it out. Cannot submit pictures on here due to guidelines, so I’ll try to describe the trim piece. It’s the rubber trim above the aluminum chrome trim on the door. Was thinking some sort of silicone glue or to cut off some rubber seal from something else. This is on the passenger rear door and I tried to see if I could purchase that part ,but was unable to find it.
This is the service manual dig your way
Google "Kia Stinger Door Weatherstrip"
It is a line item from all Kia dealers
If it solves your problem
THANK ME!
THANK YOU !!! I was able to find it through the service manual and figured out that it is the window glass run channel . It’s about 70$ off of eBay so I don’t know if I’m going to spend that money right away considering the area I cut out was pretty small , but one again thank you for helping.
