3.3TT Cquence rotors or R1 Concepts rotors?
R1concepts or Cquence drilled & slotted rotors?
  • R1concepts
    Votes: 11 35.5%
  • Cquence
    Votes: 20 64.5%
  • Total voters
    31
Anyone else with more feedback? Looks like 4/4 chose Cquence so far and has me leaning that way.
I am a Lexus owner,... RC350 F sport. I bought some Cquence x-drilled / slotted rotors, ceramic pads.... and squeaked from day one. I changed pads.... still squeaked. I had two different installers for that. So, then I had a second set sent,... got a 3rd manufacturer of pads, 3rd installer that is a high end brake shop here,... same thing!!! I'm almost beginning to believe Cquence have a bad design. I refuse to believe 2 sets of rotors, 3 sets of pads, and 3 different installers can all achieve the same results... that's nuts! I am looking at R1 concepts to replace them before ultimately having to go back to stock ( 2 piece up front, 1 piece in rear ). Any of you have issues with noise with either of your purchases??
R1 Concepts Geomet cross drilled and slotted rotors using OEM pads all around. Much better than stock. No squeak at all.
Are your OEM semi metallic? Lexus are super dusty, so I have traditionally used ceramic. This is first of 4 cars with this setup to be a problem... but also first time using Cquence
Are you aware that your are putting those nice rotors at risk for deposits and possibly cementite deposits to form with the stock pads? You might be well severed to put some aftermarket pads on, especially in the front.
I went with the Akebono Performance Ultra Premium Ceramic pads(Akebono PERFORMANCE Ultra-Premium Ceramic Pads) and they completely eliminated my shutter/brake deposits, but they did squeak initially. I learned that performance pads and even ceramic pads will squeak unless used with occasional moderate/heavy braking. As soon as I began adding one or two heavier braking sessions during my drives it went away.
I highly doubt it’s the rotors causing squeaking and most likely the pads themselves, especially if they are higher performance pads.
Did you change out your rotors? Or are you still running OEM? Did you have your stock rotors turned?
Both. I’m still running OEM rotors, but had them resurfaced twice, then completely replaced by Kia and then resurfaced again so I gave up on the stock pads. They are definitely the problem and once I upgraded the front pads with the Akebonos my shuttering and pad deposits completely went away.
Uuuuugh. My head throbs every time someone says "wrapped rotors" that's not a thing! Built and ACTUALLY raced cars for 20 years. The rotors have deposits on them, there it no argument to be made for warped rotors. It a myth
Not sure which ones we got on the group buy, I think it was the performance. I did get crossed drilled and slotted.
Here are some photos.
Hello, I was curious where you ordered the brake lines from? I am having trouble finding the rears. Thank you in advance
Hello, I was curious where you ordered the brake lines from? I am having trouble finding the rears. Thank you in advance will be able to source them for you
Nick @Khartunerz will be able to source them for you.
