FF.Aaron
- Nov 11, 2019
So I purchased my 2018 GT2 knowing full well the previous owner had a cooling issue. It was such low mileage that I figured it was still worth it at the price, but now the issue is starting to manifest just in a couple of days. I realized that there is a sloshing noise coming from the front of the car while driving, which would indicate an air bubble in the coolant. I put the heat all the way on high, and sure enough there was heat...until I were to come to a stop then eventually it would blow ice cold until I were to move again (I don't keep the engine shut off feature at stop on, so whenever the engine was at a mere idle it wasn't enough to get coolant to the heater core). Sure enough I get around to checking the reservoir and its empty.
Should my course of action here be to just fill the reservoir with 50/50 coolant, leave the radiator cap open as the engine idles up to operating temp and hopefully the air bubble gets burped out? What more catastrophic issues could be at hand, considering whenever I drive this car the engine temps never go above half so it doesn't seem like its overheating?
