I drained and refilled my coolant. I have a vacuum (Airlift clone) filler, which generally does a good job of getting all the air bubbles, but not on the Stinger. After the fill I squeezed the upper and lower radiator hoses and let it idle for about 10 minutes with the heat on and I couldn't get any warm air through the vents. I opened up the "coolant vent hose", lifted the front of the car and continued squeezing the upper and lower hoses until nothing but coolant came out of the hose and let it idle again. This time I got warm air from the vents but it didn't get hot until I started moving the car. During a 10 minute drive, the coolant needle stayed planted just below half way mark but at the end I came to a stop and the air from the vents was cold again. The coolant wasn't under pressure when I checked the fill cap. Added more coolant, squeezed the hoses again, and drove the car again and now I'm getting hot air from the vents at the end of the 15 minute drive. I think I've got it now, but what a pain. Usually the vacuum system works great so it' disappointing to have this going on with the car.
It's 20F outside so if I'm going to have overheating issues, I won't see it today.
Has anyone done this with better success without a KDS?
