Coil wires
damimissed
Does anyone happen to know the part number for the 2.0 coil wires?i can find the coil all day but not the wires themselves. I dont need the whole wiring harness just for the ar. i just need the spark plug coil wiring harness
Moving this into the Stinger section where it will get more attention.
I thought the wire's attached to the coils are part of some main harness? What's wrong with yours?
Ouch. Not making an insurance claim?
Sometimes you can find the shells if you dig hard enough. Some aftermarket replacements come with ~6" pigtails. I have no idea if Kia stuff is available. You can check other Kia models on rockauto.com and see if there are any connectors that look the same. And there's a very, very slight chance that your dealer can help.
If you're fixing it yourself then you're probably best off just splicing things back together. If the damage is bad enough that you can't tell what went where then you'd need a new harness anyway.
