Coding our Stingers is possible! (Variant Coding over OBD2 Port)
Saschaversum
Switzerland
Hey Guys
So i cam across this Russian Company that does all sorts if CAN hacking. Apparently they have decrypted the obd encryption in our stingers.
I had a long talk with them on Whatsapp and they provided me with all documentstion and have a local dealer around 3hrs away from my home in switzerland(dealer is in germany).
You can use variant coding if you are up to analyze the can traffic and possibly do all sort of modifications.they do provide some coed for tpms disable for example. But they also provide a simple menu where you can set certain parameters.
These would be: sport+ or custom mode set, active hood set, vmax limiter removal, gt menu enable for gt lines, shift indicator enable, region set, disable automatic start stop, led lights set, service intervall modifications or reset and also odo meter altercation which obviously i do not encourage.
Its „only“ 350bucks. Im very tempted to get it because i really want the custom mode since sport+ is just sport with traction control turned off.
Here the product link: https://canhacker.com/product/ch-obd-fd-coderl2/
Attached also a pic of the settings menu. There is also a russian youtube video from them.
I suposse no one in the forum already tried and i would be the guinea pig? C66EC696-C601-427A-B096-D453D4FB022F.webp2D77486A-32F7-4B51-8515-AEA96F079AC5.webp
What exactly is "active hood"?
Description
The system reduces injury of pedestrians by lifting the hood when a accident occurs between the pedestrian and vehicle.
It may prevent a secondary impact between the pedestrian's head and engine components.
Their equipment and software is what I used to reprogram a gauge cluster from a wrecked GT2 for use in my GTS so I know their stuff works.
