StingerOwner
- Oct 22, 2023
I have an AWD Kia Stinger GT. I tried doing some donuts in the snow. I did it in SPORT+ mode while being manually shifted to either 1st or 2nd gear (tried both). Keep it mind that SPORT+ only disables traction control but leaves stability control on.
Once I had enough, I stopped the car and stepped outside and could smell a distinctive burning smell - perhaps similar to methane or sulfur or something like that. I remembered this smell from one time when I was a passenger and the driver burnt the clutch in a manual transmission car.
These are the thoughts I have what burning smell it could have been:
Thanks.
- Clutch for some unknown reason - as I wrote I recognized this smell from past. But I don't quite understand how I could have damaged the clutch. I was literally just going in circles and moderately rapidly switching between pressing gas/letting go of gas.
- Brakes - I had traction control off but stability control was on. I believe stability control automatically applies brakes as it sees fit. Maybe brakes were being applied a lot?
- Clutch due to doing this in 2nd gear. Maybe doing donuts in 2nd gear is not good? Or could clutch be damaged if I accidentally take off from a stop in 2nd gear instead of 1st? Pretty sure I always started in 1st from a stop, but maybe mistakenly did it in 2nd.
- Tyres - tarmac was visible in a few places and could have eaten the tyres a bit but the burning smell didn't seem like from rubber.
Thanks.
