Climate control unit change
Pacco
Lethbridge
Does anyone know how to change the display units from Fahrenheit to Celsius?
You should be able to use the steering wheel mounted controls for the LCD display to go to user settings and scroll to Temperature Unit...
Or if you are talking about the number you see when you are setting the temperature do this:
Temperature conversion
You can switch the temperature mode from Centigrade to Fahrenheit as follows:
While pressing the OFF button, press the AUTO button for 3 seconds or more. The display will change from Centigrade to Fahrenheit, or from Fahrenheit to Centigrade. If the battery has been discharged or disconnected, the temperature mode display will reset to Fahrenheit.
It's in the settings. Need to be in Park.
