Change Harman Kardon midrange speakers Kia Stinger
OK I just improved my sound system further. I found some helpful ideas for those who are interested.
1) the factory sound processor set the bass and treble up. So to 'de-equalise' the factory tune, set the bass to -10 and Treble to -5.
2) build in amplifier is class D. So for it to work properly with other it need to have a 'dummy speaker load' before you feed it to another amplifier. You will find significant improvement in distortion.
Audison calls it universal speaker simulator: USS 4 | Audison - car audio processors, amplifiers and speakers
Audiocontrol calls it Load Generating Device: AC LGD's: Do your line converters put a resistor load on the speaker outputs of my factory amp? | AudioControl
Focal hi Lo V3 has a dummy load build-in. I used one for subwoofer channel and it works really well. Noticeable improvement. Focal HILO.V3 - Stereo Amplified Signal Converter. V1 and V2 do not have the feature built in.
I also used cheap 10w27ohm ceramic resistors for the other 9 channels and it works just as well.
3) Digital signal processor (DSP) helps. I used a 4 channel Audison Bitten for the 4 mid-range and tweeter pairs. I tune it with an Andriod app call Audio Tools with a calibrated iMM-6 microphone from Dayton Audio.
This is my current upgraded setup.
This is the sound frequency sweep that I got from this with Bass set to -10 and Treble set to -5'
Hope that helps
that was sweet tech ass-istance :)
Ah, I see you found Andrew already (ignore what I said on the other thread :P).
Just change the mid range speaker because I was not happy with the Audiopipe crossover setup. It uses a resistor to reduce the volume of the tweeter (89 db/w) to match the volumn of the Vifa midrange speaker (83 db/w). Unfortunately, the resister also reduces the high frequency clarity of the tweeter.
So I went to buy a 'high sensitivity' midrange speaker which match the output of the tweeter (88 db/w). With a lot of trial and error I ended up using a simple coil inductor and capacitor for the crossover. I also removed the metal grill plate and use speaker cloth instead. The end result is a significant improvement in mid and high frequency clarity.
For those who are interested, that is using a 1st order Butterworth crossover @ 4800Hz. For those who even want it simpler, just use the capacitor and don't worry about the inductor. The end result is hardly noticeable.
